awato
Unintentional file renaming when installing via MSI
Dear Team,
I have a problem with an MSI project. The thing is, three of my 82 files that I need for the installer are renamed during setup. The affected files receive a prefix “File.” This means that if the name of the source file is "Filename.dll", after installation via the MSI package it will be "File.Filename.dll". I haven't been able to figure out why this happens yet. Can someone please help me so that the file names are not changed?! Thank you and best regards, Thomas
awato
Re: Unintentional file renaming when installing via MSI
Found it!
There are a few translations in the project. File and folder names have also been translated (which may be a default setting). The translations must be entered by hand, i.e. if a new file is added to the project, the translation must be carried out manually. Otherwise you will have the problem that I described above.
I have excluded the translation of file and folder names, which solved our problem.
translations
translations
Thank you for your followup on this and for sharing the solution with us. I'm glad you managed to find the culprit. :)
awato
Dear Catalin,
you are welcome :D :lol:
Thank you very much for your reply
Thomas
You're always welcome, Thomas! :)
