lllgnslbdllssr
How to set IIS app pool identity credentials from dialog user input
Hi everybody,
I need to install a web application in IIS environment.
So I want that a user types some user credentials (I know that this user must exist on machine) and this user must be used as the application pool execution user. How I can achieve that?
Re: How to set IIS app pool identity credentials from dialog user input
You can achieve that by using the properties that the user inputs (e.g. POOL_ACCOUNT and POOL_PASSWORD) and then use them in IIS page --> your application pool --> "Identity" tab.
