ima-aa
Conditional Desktop Icon
Hello, my goal would be to create a desktop icon that has the condition that a checkbox is set during the installation.
I have found the following article.
https://www.advancedinstaller.com/user- ... tcuts.html
However, whenever I want to create a shortcut to an external file, it takes a random component. I can also create these dummy registry entries. it usually takes a dll as a component of the external shortcut. What is the logic here? What is selected here by default?
thanks Andreas
Re: Conditional Desktop Icon
Hello Andreas,
You can always move the file (in our case, the shortcut) from a component to another.
You can do so by going to "Organization" page, expand the component that contains your shortcut, right click on it --> "Move to new component".
Note: if you have many components and it's hard for you to find the component which contains your shortcut, you can go to "Files and Folders" page, right click on your shortcut --> "Go to component".
