Similitran
Windows-Authentication in IIS enabled when installing WebApplication under Default Web Site
Hi
I have the issue when installing a Web Application under Default Web Site in ISS that the IIS Feature "Windows Authentication" gets enabled. This leads to problems with our Web Application. Is there a way to avoid this?
Many thanks
Similitran
Re: Windows-Authentication in IIS enabled when installing WebApplication under Default Web Site
Hello Similitran,
Not quite sure I fully understand your scenario here. If possible, could you please give me some more information regarding this (e.g. some screenshots would help)?
Are you saying that the option gets enabled despite you not having it checked in your project?
Similitran
Hi Catalin
I just discovered that there is the option to activate Windows Authentication under the authentication tab of the web applications.
Now it's not enabled anymore in the IIS feature after the installation.
Thank you for your followup on this and for sharing the solution with us. :)
Glad to hear everything is working as expected now.
