mli04
How to modify property values in exe file
Hi ,
I have been using Wix Toolset to create custom Actions. I can easily pass information through properties in Actions (modify property values, read property values). The following is an example of Action.
[CustomAction]
        public static ActionResult ValidateUserAccountAction(Session session)
            session.Log("Begin ValidateUserAccountAction");
            const string sessionResultName = "USERACCOUNT_VALIDATION_RESULT";
            try
                if (!ValidateUsername(session))
                    session[sessionResultName] = "False";
                    return ActionResult.Success;
                if (!ValidatePassword(session))
                session["CREDENTIAL_STRING"] = CredentialFileUtils.BuildUserCredential();
                session[sessionResultName] = "True";
            catch (Exception e)
                session["ACTION_MESSAGE"] = Properties.Resources.StringUnknownError;
                session.Log("ValidateUserAccountAction: " + e.Message);
            finally
                session.Log("End ValidateUserAccountAction");
Recently I have a .NET 7 project and I can no longer use Wix Toolset to create custom Actions because Wix Toolset does not support .NET 7.
So I want to create an exe file based on .NET 7, and contain all the Custom Actions in this exe file. My question is how to read and modify the property values in the Custom Action of this exe?
Re: How to modify property values in exe file
Please have a look over our "How to create a .NET Custom Action" which should cover what you need.
mli04
My Advanced Installer version is 19.0. I did not find "Call method from .Net assembly" in the custom Action. Are there any other solutions?
Andrew
Hello Andrew,
Indeed, we have added this support recently as many clients requested it.
I'm afraid I am not aware of any other solutions.
