Tam
Running CLI without interactive context
Within our development process, we use Advanced Installer to create a .msi file on a EC2 windows instance that does not have an interactive context and it keeps hanging. After awhile we figure out if we RDP into that instance with the same credential before running the build CLI then it works. Can the CLI be used without an interactive context?
Re: Running CLI without interactive context
Please allow me some more time to discuss this with my team and I will followup as soon as I will have a conclusive answer.
When logging into the machine, do you perhaps see any prompts related to Advanced Installer that require manual intervention?
Upon further discussing this with my team, it looks like what you want to achieve should be possible.
However, please make sure you are calling AdvancedInstaller.com (not .exe) in your scripts.
