RUGhost320
Advanced Installer showing update dialogue of my application repeatedly
I am trying to learn Advanced Installer Automatic Update feature. The Updater of my XYZ application showing update dialogue for every 5 minutes and showing XYZ is up to date. But I want after launching XYZ application it will check update without showing update dialogue and if it finds any newer version of XYZ application, only then it will show the update dialogue.
Re: Advanced Installer showing update dialogue of my application repeatedly
In order to achieve that, you can launch your updater using the /silent command.
