derekjfrei
Can only install in debug mode after upgrading
I am working on upgrading a legacy project from Advanced Installer 7.7 to 21.7.1. After doing this, I can only install my application in debug mode (AI_DEBUGLOG=1). If I specify the debug flag, the installation works as expected. If I do not, the installation immediately shuts down, and none of the custom actions in my project are executed. Any advice on troubleshooting this would be appreciated.
Re: Can only install in debug mode after upgrading
I'm afraid that considering the discrepancy between the two versions you are using, I can not really say for sure why this is happening.
If possible, could you please forward me the following resources:
- a copy of the AIP file used in 7.7
- a copy of the AIP file used in 21.7.1
- a download link for the setup (built with 21.7.1 after upgrade)
by email at support at advancedinstaller dot com so I can further investigate this?
