aabot
Extract Archive to folder has "Access is denied"
In my installer, I want to extract the contents of a zip file to a folder created under the Application folder. When the installer runs, I keep getting "Access is denied".
I have mongodb-windows-x86_64-4.4.26.zip extracted to a mongodb\ folder in the same parent folder. I setup an extract archive and for the source path have [mongodb_Dir]. In the UI, I added permissions to the mongodb folder to grant full control to everyone.
I build the installer and then run the installer. The installer runs until the "Access is denied. .... C:\Program Files\....\mongodb".
How can I extract the archive into the folder?
Re: Extract Archive to folder has "Access is denied"
I have tested this scenario and everything worked as expected on my end.
If possible, could you please create a sample project that reproduces this and forward that to me by email at support at advancedinstaller dot com?
aabot
I created a small sample and sent to the email address you gave.
In the sample, I have a 1-level Application Folder with two folders mongodb and nodejs. I want to change the permissions for those directories to full access. I added the related mongodb and nodejs zip files. I then created two file operations to extract the respective archive and put it into the corresponding directory.
Aaron
Hello Aaron,
I think this might be something on your end regarding permissions.
I have built the project file you provided and then ran the MSI file and everything worked as expected:
Unfortunately, I can not say for sure what's going on on your machine, but I would suggest trying the setup on a clean VM as well to see whether you're still able to reproduce this or not.
