gopinathrbe
Windows 11 Explorer does not restart after uninstalling
Application Version 21.7.1
Steps to Replicate the Issue:
Install the application using the setup.
Right-click on any .rfa file to open the context menu and use it.
"Uninstall" the application using the setup
In the uninstaller window, choose the option for "Auto Close" and proceed by clicking "OK" on next window. This action results in crashing the file explorer.
SampleToShare.zip
(700.37 KiB) Downloaded 311 times
Re: Windows 11 Explorer does not restart after uninstalling
Please note that the FileInUse dialog that you are seing is not proprietary to us, but to Windows Installer.
That being said, there isn't any way in which we can control/affect it's behavior.
Please let me know if there is anything else I could help you with and I will gladly assist.
gopinathrbe
Any workaround to avoid crashing the explorer? Can you share the same files?
I think you might have hit a corner case here, which unfortunately I do not know how to work around.
