MGS
Skipping custom dialogs on patch/upgrade/update
We have a few custom dialogs which are required for the first time install.
When upgrading/updating our product these dialogs should not be displayed. We just want a simple upgrade that overwrites updated files with the newer version.
How can we do this?
Kilian
Re: Skipping custom dialogs on patch/upgrade/update
Hello Kilian,
In order to skip these dialogs, you can use a condition as it follows:
NOT OLDPRODUCTS
OLDPRODUCTS is a property that is set to the previous version ProductCode. As you can imagine, this is only set on upgrade.
In order to set a condition for your dialog, you can right click on it in "Dialogs" page and "Show only if...".
MGS
Thanks for the reply!
So I adapted my installer and now it shows a message box with the contents of the OLDPRODUCTS property ("OLDPRODUCTS: [OLDPRODUCTS]") during installation using a custom action. Then I created two installers (let's call them v1 and v2) using Advanced Installer. After creating v1, I regenerated the product code (to my knowledge the product code should be changed between versions, but the upgrade code has to be the same) and changed the file version of one file, then I created v2. Then I installed v1, and it showed "OLDPRODUCTS: ", therefore it was not assigned. Next, I installed v2, and it showed again "OLDPRODUCTS: ", therefore it was still not assigned. What am I missing here?
Hello Kilian,
Please note that OLDPRODUCTS is set during the "FindRelatedProducts" standard action.
This standard action is part of the "Searches" action group, so please make sure that your messagebox custom action is scheduled after that.
