thomas.trummer
Registry values not updated while Maintenance
I need the possibility to change settings by executing the installer again.
If I start the installer after initial installation and click "Add/Remove Features" I get my config dialogs shown.
With the config dialogs I can change Properties which where bound to registry values.
On the initial installation the property values will be written to the registry but while modifying the values will not be written to the registry.
I found one example which exactly does what I need but I didn't figure out what is different to my project.
I added the working aip file and the installation log and I also added the not working aip file and the log of this installation.
As you can see, the working log shows "RegAddValue" on line 1087 but the not working installer doesn't have and rows with "RegAddValue"?
Does anybody have an idea what I made wrong.
Thanks Thomas
working.zip
(25.05 KiB) Downloaded 132 times
notworking.zip
(250.93 KiB) Downloaded 145 times
thomas.trummer
Re: Registry values not updated while Maintenance
Here is a reduced version of the not working installer
notworking.zip
(31.44 KiB) Downloaded 126 times
thomas.trummer
I found the difference between the two AIP files.
The difference is that the Add or Remove Features and Repair/Reinstall buttons contain a Reinstall one or more features event.
I don't know if this is correct and if I understand it correctly, but it seems that setting this event argument to "ALL" always updates the registry values ​​and JSON configuration files for all installed features, even if they were already installed.
Indeed, this is the correct method. Windows Installer does not support modifying registry entries during Maintenance.
Basically, the components of the registry entries should be reinstalled.
