Makaveli
Opening aip File Error
hi there, when I try to reload/open my aip file I get an The application ran into a problem that it coudnt handle error .You can find the error below
[SEH_AV_READ_BADPTR] ACCESS_VIOLATION (0xc0000005) at address [0x00cb2e7b]
Advanced Installer 21.8 build ad6d1cd2
*** Stack Trace (x86) ***
[0x00cb2e7b] -----
[0x00e2f7cb] -----
[0x756b21bb] free_base()
[0x756b2188] free()
[0x00a031f2] -----
[0x00e0f76e] -----
[0x00c0dad9] -----
[0x74b73207] NLG_Return()
[0x00e0c3c0] -----
[0x00a50740] -----
[0x6879f208] XML_GetFeatureList()
[0x00a4d110] -----
[0x6878a826] XML_GetFeatureList()
[0x68784065] XML_GetFeatureList()
[0x0086d1cf] -----
[0x68787a68] XML_GetFeatureList()
[0x68785780] XML_GetFeatureList()
[0x6878266c] XML_ParseBuffer()
[0x0086cdbe] -----
[0x00628867] -----
[0x00a521a9] -----
[0x00a49c6f] -----
[0x00a533f7] -----
[0x0100c5f8] -----
[0xffeeffee] -----
[0x00210000] MODULE_BASE_ADDRESS
I guess that a file is probably missing here, what can I do to open this project successfully in advanced installer.
Plus I have a working exe output of this project. Is it possible for me to reload the project by repackaging the exe ?
I am looking forward to hear a solution from you,the screenshot is also attached
Thanks in advance
ADV INSTALLER ERROR.png (44.04 KiB) Viewed 3460 times
Re: Opening aip File Error
Can you please send us the .AIP (setup project) file by email to support at advancedinstaller dot com so we can further test and investigate this?
Makaveli
Of course I can send it to you, but the problem is there are too man files and directories related with this project too. Will it be necessary only to send the aip file for you to solve the problem ?
Yes, first forward us the .AIP project file and all dialog dependencies in the repository related to the main .AIP project (if you have any).
"C:\ProgramData\Caphyon\Advanced Installer\Repository\Dialogs\"
