jmoleary
Minor issue in installer for AI
This is not really a problem that I am having with AI. Instead, it is a problem that the installer for Advanced Installer itself is having. An extremely minor one I just thought you would want to know about.
When I ran the most recent update, the status text (e.g. "Removing Shortcuts") was overwriting the word "Status" in the UI. I attached an image with the area I'm talking about highlighted in a red rectangle.
Just figured someone might want to know
Re: Minor issue in installer for AI
Thank you for reporting this issue.
Unfortunately, I'm unable to reproduce it.
Can you please send us the OS version and build number? We also need the display resolution and DPI (scale) of the operating system.
jmoleary
I am running Windows 11. The most recent Version that Windows update will allow me
Under the "Scale & Layout" section I see
Scale: 100% (Recommended)
Display Resolution 2560 x 1600 (Recommended)
Display Orientation: Landscape.
Note that I have two monitors, giving me one single single wide desktop
I tried to reproduce this problem using the same settings as you, but failed.
I will forward this scenario to our QA team, hopefully they will be able to isolate this issue.
Thank you for bringing this to our attention.
This has been fixed in version 22.9 of Advanced Installer, released July 23rd, 2025.
