anotheraiuser
Adding custom text to the Verbose log
So, I have enabled the verbose logging through the GUI and was wondering if there was a way to add a execution results to the log from a JavaScript file.
Right now I have accessed the properties inside the JavaScript and wanted to write a its result in the log. Like we have Write-Output for PowerShell scripts which writes the result in the log, is there a similar function in JavaScript that can do the same thing maybe something like Session.Log("");
Re: Adding custom text to the Verbose log
I'm afraid that I am not quite experienced when it comes to JavaScript and therefore I do not really know whether there is a function to add text to your log or not.
As per Microsoft's documentation, it would look like the Session should work from within your JScript:
Custom Action type 37
(check the "Remarks" section)
anotheraiuser
Thanks for the quick reply Catalin, the documentation was indeed helpful.
For anyone having to do the same:
You first have to import the "Session Object" and then use the Session.Message method to insert the record in the verbose log.
The links are:
https://learn.microsoft.com/en-us/windo ... ion-object (for the session object)
https://learn.microsoft.com/en-us/windo ... on-message (for the session message)
You are always welcome!
And thank you for sharing your solution with us.
I'm sure this will be of help for further users facing a similar scenario.
