gielians
Never Override in PS affects more components than selected
although this is my first post here I am using Advanced Installer within our build pipelines for more than 3 Years now, and we are quite happy with it.
In this case we use the Powershell component to fill an existing "template" project with files, components, services, etc. and build an exe installer.
Now we wanted to make some config files "Permanent" and "NeverOrverride" to create them on a fresh install and keep them as they came from the fresh install.
Here is the code block handling this.
"Set files to never overwrite"
$nonoverwritefiles = $advproj.FilesComponent.Files.Where({ $_.Name -eq "appsettings.json" })
$nonoverwritefiles.Add($advproj.FilesComponent.Files.Where({ $_.Name -eq "config.json" }))
foreach ($file in $nonoverwritefiles) {
  "Set NeverOverwrite for $($file.FullPath)"
  $file.Component.NeverOverwrite = 1
  $file.Component.Permanent = 1
This works fine for the files we want to keep (all "appsettings.json" and "config.json" files), but it also affects all other ".json" files that are located within the folder of one of the "appsettings.json" or "config.json" files.
.json files that do not have a "appsettings.json" or "config.json" file placed beside in the same folder are not affected and deleted/ovewritten as expected.
The log only shows changes made to the correct files
Set Files to never overwrite
Set NeverOverwrite for APPDIR\ContentServer\appsettings.json
Set NeverOverwrite for APPDIR\Manager\appsettings.json
Set NeverOverwrite for APPDIR\LiveSession\appsettings.json
Set NeverOverwrite for APPDIR\AssetStorage\config.json
Deleting the whole code block from the script makes all ".json" files be deleted/overwritten again (as expected).
I really don't see why the other files are affected by the changed made to components of other files.
Maybe some of you see the mistake right away, thanks for you help, Eric
gielians
Re: Never Override in PS affects more components than selected
"Set Files to never overwrite"
$nonoverwritefiles = $advproj.FilesComponent.Files.Where({ $_.Name -eq "appsettings.json" -or  $_.Name -eq "config.json"})
  $file.OverwriteType = "no"
fixed it
the changed had to be made to the file directly not to the component of the file because the component also includes other files
Thank you for posting a followup on this!
I am glad to hear everything is working as expected now and I'm sure this solution will be of help for further users facing a similar scenario.
If you require any further assistance, please do not hesitate to contact us and I will gladly assist.
