attiqe.rehman
Set property value from enviornment variable
I need help configuring a property, namely 'SSL_THUMPRINT', to be assigned from an environment variable with the same name. Is this possible within my setup? If it is, a detailed explanation or any supporting documentation that could assist me in this process would be highly appreciated.
Thank you in advance for your help
Attiqe
Re: Set property value from enviornment variable
Hello Attiqe and welcome to our forums,
Unfortunately, we do not have predefined support for this.
However, what we can do is a custom action that gets the value of your env variable and then sets a property accordingly.
How to set an installer property using custom actions
attiqe.rehman
Thanks, it worked.
You are always welcome! :)
