gopinathrbe
Licensing Issues on Virtual Machine
Advanced Installer-21.9
In the virtual machine, the specified license option is not working. I am receiving status code 5 even though the license key is properly applied and added to the registry. We confirmed that the user has admin rights.
Is it possible to debug the trial license library to collect more information about what is causing the issue?
Licensing Options.png (24.12 KiB) Viewed 22781 times
Re: Licensing Issues on Virtual Machine
If possible, could you please forward me the following resources:
- a copy of the AIP file
- a download link for the setup
- a test case for this + the license key so I can register
by email at support at advancedinstaller dot com so I can run some tests on my end?
Additionally, are you able to reproduce this on any VM and it works as expected on the rest of normal machines?
gopinathrbe
It happens if the user installs the application using the Citrix layer.
I'm afraid I am not quite proficient when it comes to Citrix layering.
Do you refer to this: Reference Architecture: App Layering
If so, is this available in trial mode or something so I can test the behavior?
If it is available, could you share the AIP file and a download link for the setup so I can run some tests?
gopinathrbe
Check this one https://docs.citrix.com/en-us/citrix-ap ... ing/4.html which we received from the user
After further investigations, it looks like testing this can become quite cumbersome.
I have discussed this with a colleague that has a little experience with this and I will followup up here whether we find something or not.
Thank you for your patience on this!
If possible, please forward me the following resources:
- a download link for the setup file (MSI or EXE)
by email at support at advancedinstaller dot com so this can be further investigated on our end.
gopinathrbe
The .aip file and all the necessary files to create the .exe.
Thank you for the files!
Please note I have downloaded them and will investigate this.
Additionally, I removed the ZIP file as these files shouldn't really be shared here. :)
If they were sent over the email, it would have been different.
Thank you for your further patience on this.
gopinathrbe
If I send an email, how do you know it's specific to this ticket? Do I need to mention any additional details?
For now, all is good, as I've managed to get the files and remove them in time.
For emails, yes, you can specify for instance the same name as the forum thread and I would know it's for me.
Additionally, we filter through all emails so if you mentioned my name or the thread, that'd help as well. :)
First of all, please accept my apologies for the delayed reply on this.
I have discussed this with my colleague and after better understanding how this Citrix App Layering works, I came to the conclusion that we have two "solutions":
1. trying to have the registries per-user instead of per-machine
2. trying to install the app in the OS layer instead of the APP layer
If these two do not help, I'm afraid that my expertise in the subject does not allow me to assist further.
The only thing left would be to contact Citrix support team and hopefully they will be able to further assist on this matter.
