allanwglen
Theme Bitmap Bug
There appears to be a couple bugs in User Interface -> Themes in version 22.0.
- If I navigate to User Interface -> Themes and change the Dialog Bitmap or Banner Bitmap, the preview is updated the first time. Any subsequent attempts to browse and select the same file does not update the preview. I am assuming because the same file has selected, an update of the installer preview is not effected.
- After selecting the dialog/banner bitmaps, saving the project and closing Advanced Installer then reopening, then navigating to User -> Themes again the preview shows the standard banner and dialog despite the correct filenames being shown under "Dialog Bitmap" and "Banner Bitmap", and it builds with the correct bitmaps.
These bugs are only really an issue while creating the custom bitmaps and trying to pull them into the preview to see how they look, making some changes and then trying to pull them back in again.
Glen
Re: Theme Bitmap Bug
Hello Glen and welcome to our forums,
Thank you for bringing this to our attention. I've been able to reproduce the described issues.
I have forwarded this to our development team and this will be fixed in a future version of Advanced Installer.
Rest assured that resolving this issue is our top priority, and we are committed to delivering a solution that meets your expectations. We will notify you once the fix is ready.
Hello Glen,
This has been fixed in version 22.1 of Advanced Installer.
