dawid.siwak
Msi prerequisites don't install silently
I have encountered a problem with msi prerequisites. They just straight up don't install when set to silent. It happens only in msi installer build, it works just fine with exe build. Additionally while testing on Microsoft Server 2022 Datacenter, Windows Installer Coordinator popped up and i had to cancel it 3 times (as i have 3 msi prerequisites to silently install). I have a Chained checkbox unchecked on all of them, because with it checked msi prerequisites refused to install even without silent install option (again interrupted by Windows Installer Coordinator).
Zrzut ekranu 2024-09-06 145621.png (30.05 KiB) Viewed 5845 times
Re: Msi prerequisites don't install silently
Hello Dawid and welcome to our forums,
I'm afraid I'm not sure why this is happening.
If possible, could you please forward me a copy of your AIP (Advanced Installer Project) file by email at support at advancedinstaller dot com so I can investigate its' settings and try to run some tests on my end?
dawid.siwak
I sent it to support mail.
Hello Dawid,
Thank you for providing the files!
Let's continue the thread over the email until we reach a conclusion.
