sbmrodrigo
MSIX without dialg box
I need to do a silent install on the client machine and I'm intending to do this with an MSIX.
But in all my attempts I can't remove the installation dialog screen in MSIX.
I even achieved this through powershell, but I discard this option, I just want to create an MSIX that doesn't open windows
Is this possible in advanced Installer?
Re: MSIX without dialg box
Hello Rodrigo,
Please note that this is not controled by us when you create the MSIX package using Advanced Installer.
That dialog that you are seeing appears by default for all MSIX packages.
I've had a look over Microsoft's forums and I was able to find the following in which a solution is also given:
Unable to install the new Teams (MSIX) silently
Could you please try that and let me know if it helps?
