ALIENQuake
Modiffy the 'Product cannot be installed on the following Windows versions..."
HI,
My product requires Windows 11. Setting the "Launch conditions" is easy and works out of the box. However, the resulting dialog shows the list of not supported OS'es:
I would much prefer the "Product requires the following Windows versions:..." so the user receives a clear message about what the requirements are.
Re: Modiffy the 'Product cannot be installed on the following Windows versions..."
I'm afraid this is the predefied message. You can modify it from the Table Editor page --> LaunchCondition table:
launch condition.png (114.7 KiB) Viewed 4851 times
Please note that an Enterprise license or higher is required to access the table editor. Without the table editor, you will need to create custom launch conditions with your own text.
