MGS
Installer could not write to registry value on update
During an Update/Upgrade process of a project the Registry Value seems to be deleted. Then the installer tries to write a value to this registry entry and fails with the following error:
How can i prevent the key from being deleted?
I tried setting "Preserve key content".
Kilian
Re: Installer could not write to registry value on update
Hello Kilian,
I'm not sure why this happens.
To facilitate a more in-depth investigation of this issue, could you kindly email the following resources to support at advancedinstaller dot com?
1. the .AIP project file for the old and new version.
2. an installation log when this problem occurs.
3. a download link for the old and new setup package.
MGS
Hello Liviu,
thank you. The issue was that the default value was empty and not set during the update process thus it could not write the registry value.
Kilian
Hello Kilian,
