articbowling
Not Registering .Net COM dll
We are moving from installing and registering 32 bit Net COM dlls to 64 bit dlls instead. Installer worked fine with 32 bit dlls, however it doesn't seem to be adding the COM entry to the registry. I noticed at the end of the build I get a "Registration info was removed for file EVRPresenter.dll", but the build succeeds.
Checking builds status
Build required.
Notification: [b]Registration info was successfully refreshed for file[/b]  APPDIR\EVRPresenter.dll
Notification: Registration info was successfully refreshed for file  APPDIR\EVRPresenter.dll
[ DefaultBuild ]
Building package:
\\The file path
Prepare build
Detecting MSI incompatible resources
Preparing files
Creating CAB file(s)
Preparing binaries
Creating MSI database
Writing Summary Information
Creating EXE file
Validating MSI
Total build time: 12 sec.
Notification: [b]Registration info was removed for file[/b] APPDIR\EVRPresenter.dll
Build finished successfully.
Using version 19.5, but I have also tried the latest 22.2 with the same results.
Let me know if you want the dll send directly to you or any other things that I can try to resolve this.
Joe
Re: Not Registering .Net COM dll
Hello Joe and welcome to our forums,
Yes, if possible, please forward me the resources so I can run some tests on my end.
- a copy of a 32-bit dll
- a copy of the same dll, but built for x64
- a step-by-step test case to reproduce this
Please send the resources by email at support at advancedinstaller dot com.
