bspirache
Command line parameters to change updates.txt path
I am trying to change the output folder of an Update project via command line.
I have already did that for an installer project and it works well with
 AdvancedInstaller.com /edit xxxx.aip /SetOutputLocation -buildname StandardBuild -path c:\...
Unfortunately it doesn't seem to work in the case of an Update project. What is the best way to programmatically change this value please?
Thank you very much,
Re: Command line parameters to change updates.txt path
Hello Bogdan and welcome to our forums,
I've done some tests and it looks like we do not have this support.
I will add this on our TODO list of improvements of our PowerShell automation support and this should be available in a future version of Advanced Installer.
bspirache
Thank you very much, I guess we'll find a workaround but it would surely by a nice-to-have feature.
You are always welcome, Bogdan!
Hello Bogdan,
This improvement has been added in version 22.5 of Advanced Installer.
