Ivana
Prerequisites not being installed during quiet installation
We have installer with prerequisites (they are msi files that should be installed during main package installation).
When we run it with UI, installation goes fine - it checks for prerequisites and installs them.
If we run installation quiet installation, we can see in logs that it checks if prerequisites are installed, but it does not try to install them.
Is there anything that can force installation of prerequisites when we run silent installation without UI ?
Thank you in advance!
Re: Prerequisites not being installed during quiet installation
Can you please make sure you run the silent installation from an elevated command prompt?
If it still does not work, please send us the following resources to support at advancedinstaller dot com:
1. the .AIP (setup project) file
2. a download link for your setup package
3. an installation log
