mli04
How do I display Tooltip when the entered character length reaches the max length set in the Edit Box
I have an Edit Box control that sets the maximum character length to 16, and when the maximum character length is reached, how can I display a Tooltip to tell the user that the maximum input length has been reached? And the Tooltip appears for 2 seconds and disappears.
Andrew
Re: How do I display Tooltip when the entered character length reaches the max length set in the Edit Box
Hello Andrew,
I'm afraid that you can not add a tooltip only when a condition is met.
You can, however, add a general tooltip that tells the customer that 16 is the maximum of characters that can be added.
This can be done from the "Properties" pane:
