ktriendl
Hyperlink readme control on ExitDialog is broken
The hyperlink readme functionality on the ExitDialog that you shipped with Advanced Installer 20.7 [viewtopic.php?p=130717#p130717] doesn't work at all.
Two things:
1. The input field validator forces you to enter a URL starting with a protocol, e.g. "https://www.example.com".
2. But the colon character is parsed away. When you then click on that link the website isn't found, because the URL is turned into "https//www.example.com".
Re: Hyperlink readme control on ExitDialog is broken
Hello Klaus,
I've tested this and it worked just fine on my end.
If I click the hyperlink "View readme", then the correct website is opened.
Are you configuring it differently?
ktriendl
I found the culprit.
You are right, the correct link is opened if you only change the link URL.
It doesn't work if you also change the Display Text of the link in the properties pane, e.g. to "Open [ProductName] homepage", see screenshot.
Best Regards,
Klaus
Hello Klaus,
I have tested this and I can confirm the behavior.
I have now opened a ticket and this should be fixed in a future version of Advanced Installer.
ktriendl
Quick question: is this already fixed in AdvancedInstaller 22.5?
Hello Klaus,
I'm afraid this hasn't been fixed just yet.
I'll update this thread as soon as it will.
Hello Klaus,
This has been fixed in version 22.7 of Advanced Installer.
ktriendl
Hi Catalin and team,
I can confirm this is working now.
Thank you for your outstanding work, as always!
Best Regards,
Klaus
Hello Klaus,
Thank you for the confirmation - we’re glad to hear it’s working now!
We truly appreciate your kind words.
