Portalman66
Uninstall with multiple instances setup
I have a multiple instances setup. During uninstall I have a inline powershell script that is executed "when the system is being modified (deferred)" and that needs to know which instance was selected in the MultipleInstancesDlg for uninstall. How can I achieve this?
Thank you for your help.
Portalman
Re: Uninstall with multiple instances setup
Hello Portalman,
What we can do here is write, during the installation, the InstanceId property into the registries and then retrieve it during uninstall in the PowerShell script.
Please note that this would need to be retrieved before the "Remove resources" action group, as that is when the registries will be removed from the machine.
