ak_sma
Get path from where the installer is being executed
Hi All,
I am new to advanced installer. I am trying the read a file that is located in the same directory from where the installer is being executed. I want to get the path of that folder. I will be bundling my installer.exe and a config file into a zip file. When user extracts that zip file, there will be two files, installer.exe and a config file. I want to read that config file from installer. Is there any way to do it?
Re: Get path from where the installer is being executed
If you generate an EXE in Advanced Installer, you can use the SETUPEXEDIR property to retrieve the path of the EXE file.
After that, you'd have to do some modifications of that path so that it points to the config file.
