floch
Advanced installer updates fail using Ukraine as system languge
We are having an odd problem with our updates, it fails silently when the system language is set to ukraine (both for windows 10 and 11)
Regular installation and manual upgrade works, but once we let the updater download and upgrade silently it fails without any user feedback giving a fairly nondescript error in the eventviewer:
Faulting application name: Husqvarna_Service_Hub_Updater.exe, version: 1.28.86.0, time stamp: 0x66fbf388
Faulting module name: Husqvarna_Service_Hub_Updater.exe, version: 1.28.86.0, time stamp: 0x66fbf388
Exception code: 0xc0000005
Fault offset: 0x000d704a
Faulting process id: 0x1f3c
Faulting application start time: 0x01db8cfbdde221f7
Faulting application path: C:\Users\TestUser\AppData\Local\Temp\bc12bfccc1f3f1bf5d807f7615b29df1\Husqvarna_Service_Hub_Updater.exe
Faulting module path: C:\Users\TestUser\AppData\Local\Temp\bc12bfccc1f3f1bf5d807f7615b29df1\Husqvarna_Service_Hub_Updater.exe
Report Id: 24ce6ee8-883f-46e5-b0e9-adda326efcb3
Faulting package full name:
Faulting package-relative application ID:
and the following:
Fault bucket 2136270846651624888, type 1
Event Name: APPCRASH
Response: Недоступно
Cab Id: 0
Problem signature:
P1: Husqvarna_Service_Hub_Updater.exe
P2: 1.28.86.0
P3: 66fbf388
P4: Husqvarna_Service_Hub_Updater.exe
P5: 1.28.86.0
P6: 66fbf388
P7: c0000005
P8: 000d704a
P9:
P10:
Re: Advanced installer updates fail using Ukraine as system languge
Not sure why this happens.
To facilitate a more in-depth investigation of this issue, could you kindly email the following resources to support at advancedinstaller dot com?
1. the .AIP (setup project) file for the first version and second version.
2. the updates configuration file.
3. a download link for the first version setup (so we can test the update)
4. a screenshot with the Language settings (Language & Region) on the OS where you can reproduce this.
