nchounlapane
Removing prerequisites during uninstallation of main package
On my main installer, I've added pre-requisites using the /NewPrerequisite command. Is there a way to uninstall the pre-requisites when the main installer is being uninstalled? It seems that using a powershell script wouldn't work since running it blocks any uninstalls if there is already one running?
Nick
Re: Removing prerequisites during uninstallation of main package
Hello Nick,
In order to uninstall the prerequisite when the main package is uninstalled, you should use the "Allow uninstall" option.
If the prerequisite is an MSI package, the uninstlal command line will be completed automatically.
Otherwise, you would have to do so yourself (e.g. adding an uninstall command line).
nchounlapane
This is actually what I needed. Since I added the prerequisite using /NewPrerequisite command, is there any way to update the prerequisite's Uninstall Command Line and enable Allow Uninstall from advanced installer command line?
Hello Nick,
I'm afraid that we do not have automation support for that specific request.
However, i will add this on our TODO list of improvements and it should be added in a future version of Advanced Installer.
Until that, you can check the checkbox manually and input the uninstall command line.
You are always welcome, Nick!
Hello Nick,
This improvement has been added in version 22.9 of Advanced Installer, released July 23rd, 2025.
nchounlapane
Catalin,
Thank you for the update! My follow up question: How do you set Command Line (Full UI) for Install and the Command Line for Uninstall with different values? I've found a solution to use /NewPrerequisite to set Command Line (Full UI) with -cmd_line, then add a one second delay, then use /UpdatePrequisite with -cmd_line "<enter command line>" -add_stage Uninstall. I would think there would be a more efficient way on doing this?
Nick
Hello Nick,
Currently, it’s not possible to use the -cmd_line switch more than once.
The only available workaround is the one you’ve already implemented, using the /UpdatePrerequisite option to add the command line for the Uninstall action with the -add_stage switch.
I’ll forward this to our development team to explore the possibility of improving this behavior in a future release.
We apologize for the inconvenience.
