baruchi
Default location for Browse Button
I want to set the default location for a brows button based on registry key.
This value will populate the brows text box and be the default search location.
This location will later be used as the application installation folder.
I want to check if
\HKEY_CURRENT_USER\SOFTWARE\...\V2\LastRun
exist and if yes use its value as the default for the browse.
If it does not exist use:
\HKEY_CURRENT_USER\SOFTWARE\...\V1\LastRun
Currently my install dir is set to search criteria [MYINSTALLDIR]
I created another search criteria [MYINSTALLDIR2]. I guess I can also create another search criteria to check if \HKEY_CURRENT_USER\SOFTWARE\...\V2\LastRun exists.
So at the end I want my installation dir to be MYINSTALLDIR2 if \HKEY_CURRENT_USER\SOFTWARE\...\V2\LastRun exists and if not use MYINSTALLDIR
How can I achieve this?
B.
Re: Default location for Browse Button
Indeed, you can use a search to find the value. After that, you can add a Set installer property custom action scheduled after the Searches action group and before Paths Resolution.
You can use the search result to condition the custom action. For example, if the RESULT_PROPERTY is not empty, you set the APPDIR value to the RESULT_PROPERTY property or any other value.
set property custom action.png (91.94 KiB) Viewed 8646 times
Hope this helps! Let us know if you have any questions.
