VicGar
"Application Details" missing powershell automation
Hi.
After searching at https://www.advancedinstaller.com/user- ... ation.html I can't find any reference about PowerShell properties/methods to create/remove/modify "Applications Details" elements.
Captura de pantalla 2025-03-13 125917.png (70.74 KiB) Viewed 7874 times
Is this feature missing or pending implementation?
Thanks in advance for your feedback.
Re: "Application Details" missing powershell automation
Unfortunately, we currently don't have PowerShell automation support for this page.
I have added this improvement on our TODO list and hopefully this will be implemented in a future version of Advanced Installer. Thank you for bringing this to our attention.
Unfortunately, as for this moment, since you are the only one requesting this, it has quite a low priority. However, that can change if more people will request this over the time to come.
