dlafontaine
Converting Exe To Msi for silent install
I am currently using the Advanced installer trial version to test the functionnalities.
The exe to msi convert process is working fine.
If I start the .msi alone it goes through the installation process without problem except for the fact that it prompts this window:
This package was created with a trial version of Advanced Installer. You may use it for evaluation purposes only.
When I use the .msi with the silent switches(/qn) or (/q), the installer shows in Task manager for a while and then disappears after a few minutes but nothing has been installed. Is it caused by the trial version prompt?
thank you
Re: Converting Exe To Msi for silent install
To assist us in conducting a thorough investigation of this issue, can you please send us the .AIP (setup project) file and an installation log by email to support at advancedinstaller dot com?
