susankjackson
Installation error on Windows 10
I am having trouble trying to install an application using Advanced Installer on Windows 10. Every time the files are run during the installation, the system gives an error "unable to create key in the registry". I have tried running it with administrative rights but it still fails.
So where should I check them or is there any tip to improve the fastest? Thanks you!
Re: Installation error on Windows 10
To assist us in conducting a thorough investigation of this issue, can you please send us the .AIP (setup project) file and an installation log by email to support at advancedinstaller dot com?
