oz85
Problem with unistall. Component missing
Hi everyone,
I’ve searched and read several posts, but I haven’t been able to understand what to do about the issue I’m encountering.
I have two projects with the .aip extension that are similar to each other. The only difference is that one ensures the installed application starts at PC startup, while the other does not.
I already have some versions of the application installed, but now, using the same installer that generates the usual .exe, it returns an error and doesn’t allow me to install or uninstall the application during the upgrade phase.
When I check the event log, it says that it seems a component located in the installation folder cannot be started.
I honestly don’t know how to proceed with the upgrade. Even uninstalling the application manually results in an error.
Can you help me? Thank you.
- System
- Provider
[ Name] MsiInstaller
- EventID 11721
[ Qualifiers] 0
Version 0
Level 2
Task 0
Opcode 0
Keywords 0x80000000000000
- TimeCreated
[ SystemTime] 2025-04-04T14:26:32.2256410Z
EventRecordID 39685
Correlation
- Execution
[ ProcessID] 18796
[ ThreadID] 0
Channel Application
Computer xxxxxxxx
- Security
[ UserID] S-1-5-21-3520392792-2096509307-2345796370-4113
- EventData
Prodotto: ADP Extension -- Errore 1721. Problema con il pacchetto Windows Installer. Un programma richiesto per completare questa installazione non può essere eseguito. Contattare il personale di supporto o il fornitore del pacchetto. Azione: RefreshDesktop.bat, locazione: C:\Program Files (x86)\xxxxxxxx\ADP Extension\RefreshDesktop.bat, comando:
(NULL)
(NULL)
(NULL)
(NULL)
(NULL)
7B45364346333931382D323134412D343135332D393636342D4630423231363433414134357D
Dati binari:
In word
0000: 4336457B 31393346 31322D38 342D4134
0010: 2D333531 34363639 4230462D 34363132
0020: 34414133 7D35
In byte
0000: 7B 45 36 43 46 33 39 31 {E6CF391
0008: 38 2D 32 31 34 41 2D 34 8-214A-4
0010: 31 35 33 2D 39 36 36 34 153-9664
0018: 2D 46 30 42 32 31 36 34 -F0B2164
0020: 33 41 41 34 35 7D 3AA45}
2025-04-04 16_26_27-Configurazione ADP Extension.png (6.3 KiB) Viewed 3890 times
2025-04-04 16_24_51-app 64 bit.png (11.61 KiB) Viewed 3890 times
Re: Problem with unistall. Component missing
Are you able to reproduce the uninstall issue on a clean machine?
Can you please send us by email to support at advancedinstaller dot com so we can further test and investigate this, the following resources:
1. the .AIP (setup project) file.
2. a download link for your setup package.
3. an uninstallation log.
In order to create a log for an uninstall process, you can launch the installer again with the logging command. For example: "C:\MyPackage\Setup.exe" /L*V "example.log"
You can try to clean all the unnecessary information remained on your machine about the product that fails, by using the Microsoft Fixit Tool: https://support.microsoft.com/en-us/top ... f927e1eb4d
oz85
Thank you for your reply, Liviu.
I realized I had misunderstood the concept of product code and upgrade code. I mistakenly set the same product code for two installations, which led to some conflicts. After changing the product code and performing a new installation, everything seems to be fine.
Thanks for the support.
Liviu wrote: ↑Mon Apr 07, 2025 3:35 pm Hello,
You're very welcome - I'm glad to hear you found the root of the issue!
If you have any questions, feel free to reach out.
