bogdan.condur
Advanced Installer project cannot install Microsoft Redist 2013
One of your colleagues received a new laptop and she tried to install our application created with Advanced Installer. The new laptop is a Windows 11 version 24H2, Windows Feature Experience Pack 1000.26100.66.0
Our application has a bunch of prerequisites, one of them being the Microsoft Visual C++ 2013 Redistributable.
On this new laptop, the application does not want to install the redistributable. The other Redists 2015-2019, are installing just fine.
No one else has encountered this issue before, it's an isolated case. We would like to understand why this is happening, because there's a chance it can happen to our clients as well.
I would attach the log of the installer (where I cannot see anything suspicious) but the file is too large for this website (3mb).
Do you have any idea what could cause this issue?
Re: Advanced Installer project cannot install Microsoft Redist 2013
Hello Bogdan,
I'm afraid I am not aware of anything related to VC++ Redistributable 2013 and Windows 11 24H2.
Are you using the predefined packages from Advanced Installer?
If so, could you please let me know which bitness (32 or 64) so I can run some tests on my end to see if I can reproduce the issue?
bogdan.condur
We are using the official .exes from Microsoft, downloaded from here https://www.microsoft.com/en-us/downloa ... x?id=40784 The prerequisites are added under "Feature-based" with "/quiet /norestart" as the command lines.
I've also forgot to mention that we're using AI version 19.1. If I look over the 'Launch conditions' Supported Operation Systems versions, for Windows 11 only 21H2 x64 (Preview) is available. Could this be part of the issue?
Hello Bogdan,
No, this shouldn't affect the installation of the prerequisite.
Since you've added it manually, I'm thinking the install conditions are at fault here.
The above is the condition we use if you add the prerequisite from our predefined list.
This condition is evaluated twice with the prerequisite:
- once before the prereq is installed - here the condition must be false (meaning the prereq is not already installed)
- once after the prereq is installed - here the condition must be true (meaning the prereq was installed correctly)
In your case, could you please let me know what condition have you used? It should be the same as in my screenshot to ensure correctness.
bogdan.condur
Hello Catalin,
The Install conditions is set to: 'Always install prerequisite'. I thought that this option would ensure the installation is done for sure, but it seems this is not the case afterall?
Hello Bogdan,
This is really strange.
You are right, that should be the case - the prerequisite being installed.
I have tried testing this behavior, but can't quite reproduce it.
If possible, could you please create a sample project that reproduces this and forward me the project file (AIP), so I can run some tests on my end? The AIP file should basically contain only the prerequisite, no additional files.
