sfelsheim
create user not using property for password
I am using AdvancedInstaller Enterprise edition version 22.2.
In my project I am creating a windows service with a property [SP] for the service user password. The project also creates the user if it does not already exist using the same [SP].
I read the value for [SP] from the Windows Credential Manager using a custom action inline powershell script.
# get the WCM entry for the service user
$wcmServiceUser = Get-StoredCredential -Target "service_user"
# set the installer proprties
AI_SetMsiProperty SP $wcmServiceUser.GetNetworkCredential().Password
$propValue = AI_GetMsiProperty SP
Write-Output $propValue
The installer is failing when it tries to create the user with the following error.
In the installer log, and when I run the script in AdvancedInstaller, I see script is execute properly and setting the correct value for SP
Return code: 0
Script output: "@PlanDataService2023"
Modified properties:
SP changed value to "@PlanDataService2023"
The default value for the property SP is a single double quote ("). If I set the default value to @PlanDataService2023, the creation works fine.
I verified I can manually create the user with the specified password.
I have attached my advancedInstaller project and the installer log.
Any input on how I can get this to work would be appreciated.
Thank you
PDS_Luna.aip
(354.66 KiB) Downloaded 181 times
out.txt
(96.08 KiB) Downloaded 168 times
sfelsheim
Re: create user not using property for password
Any ideas on why my inline powershell script looks like its updating the property for the service users password, but it does not?
Can you please move your PowerShell script before the Preparing action group? The user is created during the AI_ProcessAccounts action.
In your project the script is executed after the above stage, when the user is already created.
sfelsheim
Fantastic. As you can tell I am new to Advanced Installer. This worked great!
Thank you Liviu
Liviu wrote: ↑Wed May 21, 2025 1:47 pm Hello and welcome to our forums,
You're always welcome!
