twherzog07
Advanced Installer Visual Studio Project Error When Loading
Hey guys,
Whenever I attempt to load, or create, an Advanced Installer Visual Studio project, I get the following error:
Unable to cast COM object of type 'Advinst.Interop.AdvinstProjectClass' to interface type 'Advinst.Interop.IAdvinstProject'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{EA392A4A-87D8-4F35-A10F-028912A71D73}' failed due to the following error: No such interface supported (Exception from HRESULT: 0x80004002 (E_NOINTERFACE)).
I'm using Advanced Installer version 21.3.1 and the Advanced Installer for Visual Studio 2022 extension version 22.8.
Thanks in advance for any help!
dkuerten
Re: Advanced Installer Visual Studio Project Error When Loading
Can confirm this. When I open an .aip file in VisualStudio 2022 it crashes shortly after.
After that I reinstalled the older version. With both versions in paralell I can open the project but get repeated error messages and cannot save the changes.
Then I removed the newest version and I can open projects again.
I hope this information may be of use to you.
I have tested this behavior, but I'm afraid I am not able to reproduce it.
If possible, could you provide a sample SLN file that reproduces this?
Also, please have a look over @dkuerten's suggestion, as that might also help.
@dkuerten - thank you very much for your input here, it is highly appreciated! :)
