dean.kinnear
Create full install that can also update if already installed
I am trying to build an exe installer for our product.
I want the same exe to either:
1) Full install if not already present
2) Update components if installed previously.
I keep the product code and upgrade code the same, just increment the version.
I want to persist the registry keys between updates.
I want the same custom action and dialogs for both and custom actions for both.
Help! version 21.5.1
Dean Kinnear
Re: Create full install that can also update if already installed
Hello Dean and welcome to our forums,
Please note that this is happening by default if you keep the same UpgradeCode, increase the version and change the ProductCode.
How do I prevent a file or registry entry from being uninstalled or repaired?
The above article should help with this.
Not quite sure I fully understand the scenario here. Please give me some more details.
dean.kinnear
I want registry settings to only be removed on uninstall.
Right now, it is always removing registry on update as well.
I want to persist registry values between updates.
Hello Dean,
Please note that the update process consists of two steps:
- the uninstall of the previous version --> here, your registry entries are removed
- the install of the newer version
If you want to preserve the registry entries (i.e. do not remove them) on upgrade, please follow the steps presented in the article I linked above.
In a similar way, for registry keys, enable Preserve key content operation with REMOVE="ALL" condition from Registry Page for the parent key containing the registry values you want to avoid being uninstalled.
To do that, in "Registry" page right click on the key --> "Properties" -->
