poltavets
How to check for .NET 8 Desktop and ASP.NET Core Runtimes and show dialog with download link before installation
I'm building an MSI installer using Advanced Installer and I need to check before installation starts whether both of the following are present:
.NET 8 Desktop Runtime (x64)
ASP.NET Core Runtime 8 (x64)
Requirements:
The check must occur before any files are copied
If either runtime is missing, the installer should display a custom dialog or message
The message should include a clickable link to the official .NET 8 download page
The check should not rely on registry searches — I prefer using dotnet --list-runtimes or other safe method
Ideally, if:
Only Desktop Runtime is missing → show a message with link to that
Only ASP.NET Core Runtime is missing → show separate message
Both missing → show a combined message
What's the best way to implement this using PowerShell Custom Actions, Launch Conditions, or Prerequisites?
I’d also appreciate sample scripts or a best-practice approach.
Re: How to check for .NET 8 Desktop and ASP.NET Core Runtimes and show dialog with download link before installation
You can achieve this by using our Prerequisites support.
You can add these prerequisites from our predefined list and move them before main package.
predefined prereq.png (44.97 KiB) Viewed 3262 times
These prerequisites will be installed based on the install conditions defined in the Conditions tab.
prereq dialog.png (106.9 KiB) Viewed 3262 times
You're always welcome!
