iridales
Problem removing record in Add/Remove programs
Hey,
After I moved some files I am having trouble removing the record in Add/Remove programs on W2K. The change and remove buttons are grayed out. I have tried uninstalling it and managed to clean some of it out but something is remaining. This is also preventing me from reinstalling the software to try and fix it. I have looked in the registary and all references to the software I was installing have been removed.
Does someone where or how to remove the peices remaining?
Re: Problem removing record in Add/Remove programs
You can try to clean all the unnecessary information remained on your machine about the product that fails, by using the Microsoft Fixit Tool:
https://support.microsoft.com/en-us/top ... f927e1eb4d
