drocx
Advanced Installer on Azure DevOps Docker Agent
We want to change our Azure DevOps build environment. We currently use physical build servers to create our release. Now we want to switch this to Docker Images with Azure DevOps Pipeline Agents.
Installing Advanced Installer within the Docker Agent worked. But how can we assign it a floating license via the command line?
Or is there a special CLI license?
Regards
Re: Advanced Installer on Azure DevOps Docker Agent
Hello Daniel,
For more information about this, please have a look over the following article:
Register Advanced Installer using the command line
drocx
Works perfectly. Thank you very much.
You are always welcome! :D
