padge.jas@gmail.com
Registry value selection. Missing registry entries in AI.
We are currently evaluating the professional edition V.22.9.1. We had issues with conditional based prerecquiste installs. Currently we can't get Amazon Corretto to install correctly no matter what we try.
In attempt to resolve those issues we tried editing the condition to match version info in the Windows Registry however. Reg entries/keys we can see in the stanadrd Windows Registry Editor are not present in the Advansed Installer registrey selection box. We have also tried to skip that by copying and paste the reg/key location directly e.g. HKLM\SOFTWARE\JavaSoft\JDK\CurrentVersion and always receive a failure on "evaluation". Other keys we can see in AI return a SUCCESS.
See attached....
What are we missing? Thanks!
Last edited by padge.jas@gmail.com on Mon Aug 25, 2025 3:53 pm, edited 1 time in total.
Re: Registry value selection. Missing registry entries in AI.
If possible, could you please try to reattach the screenshot as it seems you forgot to do so?
Also, please have a look over the following:
Prerequisite install detection criteria - How to create one
I have written that article especially cases like yours, when a custom condition has to be created.
padge.jas@gmail.com
I have attached it to the original post. Thank you.
Thank you for posting the screenshot.
Even if the entry is missing from the "picker" function, you can still input it manually in the field and it should have the desired result.
In your case, you can input manually HKLM:\SOFTWARE\JavaSoft\JDK and it should work just fine.
To test this, I would advise launching the installer directly, instead of using the "evaluate" button.
Also, I would advise testing this on a VM, especially if you want to do successive tests.
