I have a feature that requires the “SQL Server OLE DB Driver 18 x64.” In order to install this silently, I need administrator permissions, so I have configured the setup accordingly. When reinstalling the feature, this works without any problems. However, when I try to add the feature later (Add or remove software\modify), I get an error message.
- Error.png (130.49 KiB) Viewed 2098 times
When I start the setup explicitly via an Admin Console, the installation works. It therefore appears that the setup via (Add or remove software\modify) is not started as an administrator.
- Ok.png (126.62 KiB) Viewed 2098 times
Sample project
