Joshr
Advanced Installer UI Layout Issue
I'm running Advanced Installer 23.3 and running into an issue where if any of the info panes in the "View" tab are enabled (Output, Issues, Run, References, etc.), the pane does not appear and the content of the left pane and main window pane are truncated. My screen resolution is 1920x1080 at 100% resolution scale.
The "AdvancedInstaller-PaneOff.png" attachment shows what I would expect to see when the output panes are disabled. Notice that I can scroll to the bottom of the left pane and see "Custom Behavior" and its children:
The "AdvancedInstaller-IssuesPane.png" attachment has the "Issues" pane enabled under the "View" tab. There is no pane visible and the content of the left pane and content panes are now truncated. The scrollbar in the left pane, for example, is scrolled all the way to the bottom, but everything below "User Interface" is cut off. Also, there is more options displayed in the main pane below the "Custom name" field, but they are not accessible because there is no scrollbar visible:
Re: Advanced Installer UI Layout Issue
Indeed, there are currently some known issues with the Info panels on different DPI settings.
Could you let me know if you are using two monitors with different DPI scaling? So far, we have only been able to reproduce this issue in that scenario, and our development team is actively working on a fix.
When you encounter this problem, you can reset the window settings via the Registry Editor by deleting the Window Placement key value:
[HKEY_CURRENT_USER\Software\Caphyon\Advanced Installer\Settings]
"Window Placement"=-
Joshr
I do have two monitors, but they both have the same DPI scaling (100%). However, I work remotely from time to time and my home PC runs at (120%) DPI scaling and I use Remote Desktop to access my work PC.
Deleting that registry entry did resolve the issue for me, so I will use that as a work-around for now. Thank you!
You're always welcome!
Thank you for the additional details. I will pass them on to our development team.
If you have any other questions, let us know.
