hsc
AI_AIP_FOLDER isn't resolved - sometimes
I have the following problem: [|AI_AIP_FOLDER] is resolved to an empty string - in just one out of many projects. I read a forum post which indicates that there was a bug which was fixed a long time ago - can it be that it has resurfaced?
My use case is code signing. I use the "Custom" tool setting, point the path to powershell.exe, and pass this command line:
-NonInteractive -NoProfile -ExecutionPolicy Bypass -File [|AI_AIP_FOLDER]build\common\SignBinaries4.ps1
I do this in many aip projects, and it has worked great so far, until I wanted to modify this one project.
For diagnosis, I changed the tool path to C:\Windows\System32\cmd.exe, and prepended the command line with "/k echo " so that I can inspect the generated command in Windows Task Manager. And it is true, while in one project the "-File" parameter starts with the directory where the aip file is, for the other project the path starts with "build\common".
I compared all project settings and found no differences. Looking through the revision history, I find that both aip files were created in 2019, only 3 hours apart. Currently, I am using AI version 23.4.
Thanks for your help.
Hans
Re: AI_AIP_FOLDER isn't resolved - sometimes
Hello Hans,
I have tried testing this, but I'm afraid I was not able to reproduce the behavior on my end.
I have tested this via our post-build events where I call a PS1 script that resides near the AIP file and that worked on my end.
If possible, could you please provide a sample project where this reproduces and forward that to me so I can further test and investigate this?
hsc
Hello Catalin,
I emailed the project and some instructions on how to produce the problem to support at advancedinstaller dot com. Thanks for your message!
Best regards, Hans
Hello Hans,
Let's continue this over the email thread until we reach a conclusion regarding this behavior.
hsc
Update - the issue was fixed in version 23.6.
Hello Hans,
Glad to hear that this was fixed. :)
