AKIRA
Multilingual package installer hangs when launched with keyboard pressed
Dear Advanced Installer Team,
Regarding the multilingual installer, under certain circumstances, if you start it while holding down a key on the keyboard, it may hang and become unresponsive.
The following explains how to reproduce this issue:
Execution environment: Windows 11 Pro 24H2, 25H2
Tool version: Advanced Installer Enterprise 23.5.1
1. Create a new "MSI installer"
2. Select any additional languages ​​in "Translations"
3. Select "Install Parameters" -> "Installation Options" -> "Run as administrator"
4. Select "Options" -> "Create only a multilingual package" and "User Interface Language" -> "Display language selection dialog" and build.
5. Open Explorer containing the generated installer using "Open Output Folder"
6. Close all windows except the Explorer window opened in step 5.
7. Open setup.exe, and when the UAC prompt appears, hold down any key (e.g., Ctrl).
8. Click "Yes" in the UAC prompt to launch the installer.
Doing this will cause the mouse to enter a standby state and become completely unresponsive. Alt+F4 and other commands will also not work, and you will need to kill the task in Task Manager to close the wizard.
I've attached an .aip file for reference.
Your Application.aip
(20.13 KiB) Downloaded 205 times
This issue could cause problems, such as a hang if the user accidentally places something on the keyboard while launching the installer.
Do you have any current solutions?
Akira
Re: Multilingual package installer hangs when launched with keyboard pressed
Hello Akira,
I've tried to reproduce this, but I couldn't.
Can you reproduce this on multiple machines or only on the build machine?
I closed all windows except for the folder containing the setup package, but I still cannot reproduce this problem.
From what I can see in the gif, your installation is starting in a different language. Can you send me a screenshot of the Windows Display Language settings on your machine? I have only tested this with English.
Also, can you please send me your setup package too and perhaps a video recording reproducing this? You can email the resources to support at advancedinstaller dot com.
