echdaron
Response throws an error (on second attempt)
Installed the trial version and we were able to generate one MST successfully. But as there was an error reported and a feature needed to be added as a result of this, we ran the Response Transform option again and got the following error (see below).
What has already been done :
1. ran this with local admin
2. wiped out the temp folder
3. verified the length of the folders
Would appreciate any pointers...
/dimi
Re: Response throws an error (on second attempt)
Hello Dimi and welcome to our forums,
I have ran a quick test on my end, but was not quite able to reproduce this.
Most likely, I have missed a step.
With that in mind, could you please share with me a test-case that I can follow in order to reproduce this on my end, so I can further investigate this behavior?
echdaron
Appreciate the response and glad to be here :-)
Well, sharing a test-case : would love to do this but the app that we were trying to capture is Attachmate Reflection 14.0.7152 - I can't share the sources (for all the obvious reasons). One thing I forgot to mention is : if I try another MSI (for testing purposes) and try to create a MST, this seems to work nicely. It's just that Reflection msi that's raising this issue...
Is there (perhaps) a log file which I can generate for troubleshooting purposes?
With kind regards,
/dimi
Hello Dimi,
If this is happening, then most likely the issue comes from the initial MSI package you have used - I mean a combination of that and some error in our product as well, for example some edge case that we are not treating well.
The only problem here is I can not find that MSI anywhere, so I can try and reproduce this and then create a ticket so our dev team can fix it in the future.
Since you also could not share the setup, I'm assuming its' download is only for paying customers? Is there perhaps the possibility of a trial so I can try to test this? I wasn't able to find anything on their website and therefore I am asking you since you are more familiar with the product.
